Internal motor inspection/results. (Pics)
What was the oil pressure with the pinched O-ring? hot/cold idle and on the throttle? My 5.3 has 150k on it and I swapped to a fbody oil pan. My oil pressure is like 40 cold and 20hot idle but goes to 40 as soon as the throttle is touched... this is with cheap vavoline dyno 5w20 oil. Just hoping I didn't pinch the oring during the install like you. Or maybe I just need to run a thicker oil as I have no many miles and my valvetrain is sewing machine like lol. I run a supercharger and love the boost!
The 22psi hot idle doesn't scare you? I personally dont like anything under 30psi hot idle an nothing less than 40 on the throttle as a min. I feel like going from a 5w20 to a 10w30 or 20w50 would add a few PSI. I know given on tolerances I wouldn't run a 20w50 but maybe a 10w30/20w50 mix as high mileage motors have looser tolerances.
