Cam Swap (w/spring change) TDC method Question
Pat I have the timing cover off so I have the cam gear/crank gear dots lined up and plan on using them as my guides instead of crank pulley. I know it will be harder to turn over with plugs in but other than that I just wanted to make sure there wasn't any other reason to pull them out.
Thanks!
