Morel 5315 lifter preload
very interesting, wonder how many times this happens and people blame the problem
on LS7 lifters
Hydrraulic Lfter / Valve Adjustment - YouTube
This video is always how I looked at hydraulic lifters also. To much preload allows a lot of error when the lifter pumps up. When I get on here and see .090 preload suggested I get alot of questions in my head as to how that could be a good thing.
I did also find that switching to castrol
Edge quieted the motor down when it was still hydraulic
Yes I believe Kip mentioned his LLSR setups being much quieter then most hydraulics. My brother just ordered a custom LLSR from Kip last week for his 383 LT1. Going from a Hydraulic 230/236 114 to a 244/256 110+4 LLSR.
That'll be a big upgrade. Should act like a 238/250, but it'll rev like you can't believe.
I literally measure each one and the. Measure the ones I have available and use the closest fit. Then I use shims to correct from there. The main thing is to make sure the pairs are level. So if I need a 010 shim, I make sure I need that same shim for both sides. You can preload the valve up to 003. So I did end up with the occasional intake valve preloaded 003 and exhaust preloaded 001 to keep the trunions level.
YRMV.
YRMV.
So just to clarify what I did.
-1.5yrs ago when finishing my build, I used the EOIC method to find my correct push rod length.
-I came up with 7.265 using a push rod checker. I then added .060 to that number for my lifter pre load with a cold engine...that gave me a total length of 7.325
-I purchased a set of 7.325 Manley push rods and installed them. Car runs great, pulls clear out to 7k plus like lightning.
Fast forward to this thread and it got me thinking that possibly my push rods were a tad short because I do get some sewing machine noise once the oil gets up to temp. You can talk to 10 different folks knowledgeable about LS motors and it's a 50/50 split on being normal or incorrect push rod length.
So I decided to double check my initial measurements with the Bolt turn method DarthV8 uses that does not include tq'ing to 22lft lbs. This method proved that I am within .010 of my initial measurements which should be sufficient for this build. If I was running a LLSR and Shaft rockers, then yes I would want to be within .003 across each valve and I would of went even further in depth.
This was more for piece of mind because I am pretty **** about things being right no matter what it is.
Mine's pretty chattery cold, but it quiets down once oil is up to temp. A big bit of the lifter preload target depends on your target application. Someone who spends a long sustained time at rpm/WOT (should) will need to run less preload, because the valvetrain will be far more stable. In a 1/4 mile car, or grandpa's sunday driver, more preload may quiet down the valvetrain and make him happy. Doesn't mean it's optimal.
