Need Advice
Old Jul 18, 2016 | 03:05 PM
Ajdd94's Avatar
Default Need Advice
So im in the middle of rebuilding my 5.3 it came with 706 heads with the castech logo and they need a valve job bad! I can get the valve job done but my question is if its worth it? Since some say these are weak heads. The thing is im on a budget and dont want to end up spending more in the future. I was quoted $175 for the valve job and they will also check for cracks and pressure test them. I can get used 799/243 heads for 350-400 but then i would have to mill them and most likely a valve job for them as well, more money spent but i will have good long lasting heads, thanks in advance.
Old Jul 18, 2016 | 05:00 PM
HCI2000SS's Avatar
In the hands of the same porter the 5.3 is only down about 10 hp over the 243 head
Old Jul 18, 2016 | 05:21 PM
Ajdd94's Avatar
Ok so as long as the castech 706 heads check out with no cracks already then go for it? Thats what i was worried about.. all the talk about how they are prone to cracking
Old Jul 18, 2016 | 05:28 PM
HCI2000SS's Avatar
I run 862 PRC 5.3 heads, and never had a single issue. If they check I'd do it
Old Jul 18, 2016 | 06:15 PM
Ajdd94's Avatar
Thanks
