SBE LQ4 LS3 heads cam help
I have a freshened SBE gen 3 LQ4 with ARP rod bolts. I plan on running LS3 heads, BTR .660 springs and TI retainers, stock rockers with trunion upgrade, Holley hi-ram, ARH 2" primary headers with 3.5" collector, and a 250 shot. Its going in a 2600ish lb foxbody drag car with a TH400. Any suggestions would be appreciated.
The challenges with this combo is limited piston-to-valve clearance and relatively low static compression. Your choice of intake manifold and headers both lend themselves to a higher RPM range, but your piston-to-valve clearance and compression do not lend themselves to the ideal camshaft. However, with that said, a 250 shot of nitrous can fix this problem right up.
Fortunately, Cam Motion makes a camshaft exactly for what you are doing. Here it is:
http://store.cammotion.com/junkyard-...-port-camshaft
I would not recommend milling the heads any more than a .005" cleanup pass using this camshaft as valve clearance is limited. In your #2600 car, this combo should be stupid fast. Lightweight combos like this have gone mid to low 6s on motor and well into the 5s on nitrous in a well tuned car.
Thanks this is exactly what I was looking for. The choices for the intake and headers are for a later date when I can afford a built engine.
I'm not worried about low end as this car will only see track duty and will have a 4000ish stall.
