Piston and rods out of order
Old Aug 2, 2016 | 05:19 AM
HowlingMad's Avatar
Default Piston and rods out of order
So I bought anew ls1 motor and I plan on doing a stock rebuild on the bottom end. Everything looks fine and checked out fine but I've ran into a problem, the rods and pistons got moved and now I have no idea which one went in which hole, so how screwed am I? Can I just slap it back together or what? Thanks for the help.
Old Aug 2, 2016 | 10:57 AM
svslow's Avatar
Shouldn't be a problem.
Old Aug 2, 2016 | 02:11 PM
RockinWs6's Avatar
If you look real close at the wear marks on the pistons you can match them to the cylinders.
Old Aug 2, 2016 | 07:50 PM
HowlingMad's Avatar
The cylinders have been honed, not that they really needed it, but there aren't really any wear marks in the cylinders or on the pistons.
Old Aug 2, 2016 | 07:58 PM
KCS's Avatar
KCS
Moderator
You're probably ok. Since its stock crank, rods, and pistons, and the cylinders have been honed, it doesn't really matter what hole they go back into.
