Future piston recommendation for f/i
Old Aug 12, 2016 | 02:23 PM
xdanny510x's Avatar
Default Future piston recommendation for f/i
What would be a good piston recommendation for a 408 for lets say a procharged f1a ... currently my 408 has -2cc diamond pistons..my old compression was 11:8:1 .. with prc ls3 heads.. so now im tossin up the idea of a procharged motor in a 2001 trans am. .. so anyways back to piston choice should i go flat or dish? Hopefully if i resuse my eagle stroker crank and rods it will hold up to the punishment.
Old Aug 12, 2016 | 06:39 PM
DavidBoren's Avatar
I think you could use the crank, rods, and the same pistons. You could even keep the heads and 11.8:1 compression if you use E85 fuel and a custom spec'ed blower cam.
Old Aug 12, 2016 | 11:57 PM
xdanny510x's Avatar
Sold my heads already... i was thinkin about gas pump 91 octane..
