Avoid new style ls2 lifter trays
Old Aug 16, 2016 | 09:25 AM
KCS's Avatar
KCS
Moderator
I don't know about you, but my cam moves the rockers at TDC. Lol.
I just put brand new LS7 lifters and LS2 style trays in, I even weakened them further by drilled them to drain the oil out, so we'll see I guess. I plan to eventually step up to a solid roller so they'll be back out anyways in a short amount of time.
Old Aug 17, 2016 | 06:34 AM
vettenuts's Avatar
I would think the lifter bore takes out any side loading such that the trays are minimally loaded.
Old Aug 17, 2016 | 07:13 AM
speedtigger's Avatar
Old School Heavy
Consider this. The LS2 has been out since 2004? If this were a design flaw, the LS community would have it well documented.
Old Aug 17, 2016 | 07:32 AM
The_Bishop's Avatar
Originally Posted by LS1-450
This is how the lifter trays are loaded. Sketch attached to give a basic view of what is being described. Don't know why it's upside down, just rotate to view.
Your sketch completely disregards the lifter bore, which will control the angular loading you are talking about.
Old Aug 17, 2016 | 08:49 AM
kinglt-1's Avatar
Exactly...and now we already have posts stating to avoid LS2 trays in other threads.
Old Aug 17, 2016 | 11:53 AM
KCS's Avatar
KCS
Moderator
That's why I'm glad I don't build my engines based off Internet wisdom lol
Old Aug 17, 2016 | 07:49 PM
Mike Morris's Avatar
I run same combo since 2011
Old Aug 18, 2016 | 02:17 AM
SuperSport01's Avatar
I don't believe an LS2 tray is hardly any better or any worse than an LS1 tray. They are both plastic and don't remotely stand a chance of keeping the lifters from spinning in the lifter bores should something go wrong in a running engine.
For example. If you were to hold a lifter tray in your hand. Then insert a lifter into the tray. Then grip the lifter with pliers. You could by hand twist/rotate the lifter around in the tray and break the tray.
For the lifter trays to be made out of plastic they are very strong. However in my opinion the trays are to keep the lifter aligned with the lobe when its not in contact with the lobe(which is very bad for the lifters anyway), and for easy production line assembly.
Old Aug 18, 2016 | 06:30 AM
RockinWs6's Avatar
BINGO, that is their function. Once the lifter is loaded against the cam it does nothing. If the lifter floats off the cam it help guide it so it doesn't twist but it can't hold the lifter in place if the lifter has a damaged roller and actually starts to twist. Because its a not a link bar, its a plastic guide.
I just think its bazar that anyone would believe these plastic guides function as link bars?
Old Aug 18, 2016 | 06:53 PM
Jase01's Avatar
Each to their own and I know a gazillion LS engines survive just fine with the plastic trays, but if I'm doing anything with an LS for myself even just a bog stock engine rebuild, it will have linkbar lifters fitted.
Jason.
Old Aug 18, 2016 | 07:10 PM
truckdoug's Avatar
link bar lifters add weight. you need a heavier spring to keep it on the lobe.
keep it simple. make sure you have correct valve train geometry and **** will be chill.
Old Aug 18, 2016 | 08:01 PM
  #32
427's Avatar
427
I have run LS2 trays with 350 seat, 1200 open at 9200rpm without issues. I will use them over link bars every single time they will fit, and I drill holes also for oil clearing.
Kurt
Old Aug 18, 2016 | 10:59 PM
  #33
Kurt that is awesome, but there is no way I would trust a tray style lifter setup at 9000 rpm.
Doug yes link bar lifters add weight but the tradeoff in reliability is worth it. However Jesel makes a dogbone setup that replaces the trays for the best of both worlds.
Old Aug 19, 2016 | 05:51 AM
  #34
Old School Heavy
Roush Yates has developed thier own steel dog bone set up also.
Old Aug 19, 2016 | 06:06 AM
  #35
Tuskyz28's Avatar
Speed- I saw something like that.... how much they cost ?
I mean after you spend 100- 200 bucks on those then 200 bucks or more on a morel/johnson drop in lifter you'll be in the link bar price territory.
Brian Tooley once told me something about drop in lifters spinning.... but I forgot word for word exactly what he told me.
Old Aug 19, 2016 | 06:56 AM
  #36
427's Avatar
427
I use stock guides still when I can, but that is mostly 4 bolt stuff. RPM does not add any load on the centering device unless it's a link bar type.
I use dog bone and horse collar style from Jesel often in 6 bolt head engines. I will use link bar lifters on some builds, but I try not to because of lower durability and function. They are still popular because of the one size fits all design, makes things easy.
Kurt
Old Aug 19, 2016 | 08:24 AM
  #37
truckdoug's Avatar
I have seen .840 jesel link bar solid rollers as nascar take outs on ebay and they always piqued my interest, but I dont have any solid cams to try them out.
Old Aug 26, 2016 | 12:31 PM
  #38
MuhThugga's Avatar
The picture I posted earlier is an offering from Jesel, but they wanted like $700 for the things when I called and asked about them about three years ago.
Old Aug 26, 2016 | 01:24 PM
  #39
01ssreda4's Avatar
Holy hell common sense! I just installed a set of these in my LQ4 about a week ago and will not worry about it one bit. If there was a true issue with the average engine we would know about it already.
Old Jul 27, 2023 | 01:50 AM
  #40
dieselworm's Avatar
Absolutely correct. I just swapped to new Delphi LS7 Lifters with brand new trays and had a failure within 500 miles. I had my doubts about the lifter trays once I saw what was keeping the lifter true to the cam. Wish I had left the old trays in as they were stronger. The new trays spread on the wall that holds the lifter straight and kapow!
