Lq4 cam
Old Aug 13, 2016 | 09:16 PM
Firechicken96's Avatar
Default Lq4 cam
I'm fairly new to the specs of cams and their outcome so I'm going to need some help. I have a lq4 that's going with a t56 in a 1996 firebird and I'm looking for a quick off the stop car street strip car maybe eventually a twin turbo. I saw a video of a guy who did a custom grind on a ls2 it's a comp 227/234 113 .613/.612 custom grind. Anything helps
Thank you
Old Aug 13, 2016 | 09:19 PM
HCI2000SS's Avatar
Will this have the stock LQ4 heads and compression?
Old Aug 13, 2016 | 09:27 PM
Stock heads yes not sure about compression considering stock but what would you recommend?
Old Aug 13, 2016 | 09:44 PM
DavidBoren's Avatar
Honestly, the best advice I can give for cams is to get a custom cam spec'ed for you by someone who knows what they are doing, like Martin Smallwood.
If you want a simple off the shelf cam that will work well for you, something like the 224/224 on a 114, something like a 110 or 111 ICL, should be fine. Probably would work decent with a set of turbos down the road, too.
Try stick to smaller cams with less aggressive lobe profiles, and you should be fine. That is probably more a matter of personal preference and opinion, but smaller cams are usually easier to drive and tune, and less aggressive lobe profiles are generally easier on the valvetrain and make for a more stable powerband.
There are literally dozens of factors when choosing the right cam for a set up, everything from intake and exhaust to suspension and intentions and gearing, it all comes into play and the cam is responsible for making it all play nice together. That is why it is generally best to call one of the experts and tell them exactly what you have and exactly what you intend to do with it, and that way they can tell you exactly what you need.
Do yourself a favor and call Martin Smallwood, or any of the other custom cam vendors on this site. Avoid Comp Cams, once again, personal preference and opinion, but their **** sucks, go with a Martin spec'ed cam on a Cam Motion core.
Old Aug 13, 2016 | 09:46 PM
Alright will do thanks again
