Random question that popped up...
Old Aug 30, 2016 | 07:17 PM
pozesd99''s Avatar
Default Random question that popped up...
New motor set up is 11.5:1 compression. Good heads/ big cam and 91 pump gas. Have been reading and looking up member's turbo builds. Does a high compression stroker have any benifit to running meth? It would help with detonation correct? Ive never had any first hand experience, but it popped up in my head
Old Aug 30, 2016 | 07:19 PM
HCI2000SS's Avatar
Meth or E85 would almost be a necessity with 11.5:1 and boost. I run the same compression as you, and if I ever went that route I'd absolutely do it.
Also, in some cases like mine, it actually helped n/a as well, because it allowed a lot more timing without detonation, and the car responded well to that
Old Aug 30, 2016 | 07:22 PM
pozesd99''s Avatar
My car is n/a to be clear
Old Aug 30, 2016 | 07:23 PM
pozesd99''s Avatar
So it would be beneficial? Is it worth the cost? What kits would you recommend? Any links?
Thanks!
Old Aug 30, 2016 | 07:36 PM
HCI2000SS's Avatar
Beneficial for your n/a setup or for boost?
Old Aug 30, 2016 | 07:40 PM
pozesd99''s Avatar
For my 11.5:1 382ci prc225's and big cam lol
Old Aug 30, 2016 | 07:46 PM
HCI2000SS's Avatar
If your car actually wants more timing, then meth will allow you to advance it and make a little more power. You first have to determine if your car will make more power with extra timing
Old Aug 30, 2016 | 08:17 PM
Darth_V8r's Avatar
Moderator
Id say it depends on where you live. If you deal with high ambient temps, it'll help by cooling the intake air
Old Aug 30, 2016 | 08:29 PM
pozesd99''s Avatar
I live in arizona where summer nights usually dont get below 110* during the day, as hot as 120*. Fall and winter are good but i know we have shitty pump 91. Wish we had 93 octane
Old Aug 30, 2016 | 08:30 PM
Darth_V8r's Avatar
Moderator
i do too! Where in AZ? I'm in Mesa. I wish we had 93 *** swell. I've considered meth also. Blown diff changed priority
Old Aug 30, 2016 | 08:55 PM
pozesd99''s Avatar
I live in phx! I usually go out to the tempe meets. Btw if anyone out here asks about my car, it is a cam only car lol.
I am very good friends with mario, justin, brian and joe from cpr. Are you familiar with cordes racing?
Old Aug 31, 2016 | 10:17 AM
Aaron at SDPC's Avatar
If you are looking to get the most out of the setup its not a bad idea. Running methanol would allow the tuner to get more aggressive with the timing in turn hopefully making a nice increase in power. Just keep in mind though its another item on the car you will need to maintain. If the car is tuned using it you will need to make sure the system doesn't run out and that it is always operating properly to ensure you don't end up having an issue with the motor under wide open throttle conditions.
farmington's Avatar
if it didnt show any knock while getting tuned (and pulling advance) you shouldn't need it. if it would make more power with more timing, then yes.
Old Aug 31, 2016 | 10:19 AM
Darth_V8r's Avatar
Moderator
No but I've seen them pop up on searches, etc
Old Aug 31, 2016 | 10:40 AM
pozesd99''s Avatar
Thanks guys!
