Valve job numbers
Old Sep 3, 2016 | 10:29 AM
Devon Pollock's Avatar
Default Valve job numbers
Hi all just after some info from people who have had valve jobs done on 799/243 heads. Firstly was it 3 or 5 angle? What where the numbers after the machining was done? And the gains you made? Thanks.
Old Sep 12, 2016 | 06:09 PM
Cstraub's Avatar
Sir nobody that makes power is going to give you angles on cutters sir. The time spent between bench and VGS machine could be days tweaking a valve job for a given set of heads. This is the difference between a $100 valve job and a $500 valve job on a set of heads. The gain of 20 CFM in valve job is 41HP. A $100 valve job won't do that.
