thinner headgasket going to be ok to use?
Old Sep 3, 2016 | 01:34 PM
zboy2012's Avatar
Default thinner headgasket going to be ok to use?
Ok so I'm putting together my lq4 and it's going to have a some 799 heads that have been milled 1cc for clean up with a custom grind btr cam with the specs of 237/252 .622/.596 113 lsa. Now my question is do you think I'll be able to get a away with a little thinner head gasket or should I just stay with the stock gasket and go.
Old Sep 3, 2016 | 01:49 PM
Darth_V8r's Avatar
Moderator
.041"
Old Sep 3, 2016 | 01:52 PM
zboy2012's Avatar
Thanks ya
Old Sep 3, 2016 | 02:07 PM
zboy2012's Avatar
Now I won't have any ptv clearance would I? That's what I'm trying to avoid while doing this
Old Sep 3, 2016 | 02:12 PM
Darth_V8r's Avatar
Moderator
You might, but it's got more to do with your cam duration than the head gasket. If you do that extra 010 head gasket clearance won't matter. You'll want to flycut your Pistons if it's a problem
Old Sep 3, 2016 | 02:21 PM
zboy2012's Avatar
I know he spec'd to cam so I wouldn't have to fly cut
