What compression am I running?
Old Sep 28, 2016 | 12:11 AM
killingsworth73's Avatar
Default What compression am I running?
Stock bottom end LM7
Stock .051 head gasket
799 heads milled .017
I ask because I think the heads should be milled more for my cam (228r). How much more milling could I go on 91 octane?
Car is cam only, no boost.
Old Sep 28, 2016 | 12:35 AM
Can I safely mill .013 more from the heads and run a .040 head gasket?
Old Sep 28, 2016 | 06:27 AM
PhiloBo's Avatar
Hello there,
http://www.race-cars.net/calculators...alculator.html
If you know the cc of the parts you could guestimate based on above link. I would conversely refer to your blueprints and share more information for some of the ever-so-kind engine builders on here.
P
Old Sep 28, 2016 | 11:22 AM
VandykeT/A's Avatar
I'm coming up with 10.6 comp if you mill and do the .040 gasket. From what I found the stock LM7 is a -2 cc piston. Assuming thats right and the is piston flush with the top of the block that should be right. That set up should be fine on 91. I run 93 with 11.5.
Old Sep 28, 2016 | 11:54 AM
What sort of hp difference should I expect if I do this?
Old Oct 1, 2016 | 08:27 AM
VandykeT/A's Avatar
Guessing, I would say 10-12 across the board.
Old Oct 2, 2016 | 07:06 PM
1FastBrick's Avatar
FWIW, A Stock LM7 has a -8cc dish piston.
The factory 706/862 heads have approx. a 61 cc chamber.
The 799/243 is approx. a 65cc chamber.
You would need to mill approx. .030 to get the compression back If I recal. I believe it is approx .007 of mill for roughly 1 CC.
If a factory LM7 is 9.5:1 with a factory 61 CC head with .051 gasket
and you dropped to .040 gasket you would achieve 9.72:1 If you milled the 799 to match the 61 CC.
My self, I would try to achieve 58 CC to get over 10:1
You really need to measure the Piston out of the hole measurement. There typically at least +.005 to +.008 out of the hole on most of the Iron Blocks I have measured.
I have an aluminum 5.3L block right now that is +.007 on #1 hole and +.0035 On #8 hole.
You really need to measure PTV clearance based on the cam.
Stock 5.3L
Stock with .040 gasket
Stock with .040 Gasket and 58 CC chamber
