Changing pushrods, how hard is it?
Old Jun 21, 2004 | 05:52 PM
git_sum's Avatar
Default Changing pushrods, how hard is it?
Someone told me that the pushrods on the ls1's were inside the head or something and you couldn't take them out by just removing the valve covers and the intake manifold. Is there anything to this and how big of a chore is it?
Old Jun 21, 2004 | 05:57 PM
Ferocity02's Avatar
It's cake. Remove the coil brackets (5 bolts), the valve covers (4 bolts), and then the rockers (8 bolts), per side. Dont need to remove the manifold. You will need a torque wrench to torque down the rockers to 22 ft/lbs and the valve cover bolts to 9 ft/lbs i think. Not that hard at all.
Old Jun 21, 2004 | 06:39 PM
2xLS1's Avatar
Sounds like you might be getting lifters and push rods mixed up. You have to remove the heads to access the lifters on a LS1. Push rods are accessed like stated above.
Old Jun 21, 2004 | 07:30 PM
Raise's Avatar
yup, i dont even think u have to take off the rocker rail....not that thats a big job. easy job man, u could probably do it in under 2 hours. the good thing is u dont have to take off the fuel rails or intake
Old Jun 21, 2004 | 09:43 PM
slyws6's Avatar
As long as you have at least 1 capable hand and the ability to move your fingers and flex your rist then it's cake otherwise your SOL it's easy man, Ferocity02 nailed it on the head.
-Sly
