Inquiring about pistons that are better for boost
Old Oct 22, 2016 | 07:08 PM
xdanny510x's Avatar
Default Inquiring about pistons that are better for boost
So in the next months imma start to gather parts for my 408 rebuild and im definitly going boosted.. so my questions are my pistons fine i have flat -4cc diamond pistons .. or should i go more down like -10 - 15 etc? Should i stay with diamond or go wiesco if it comes down to new pistons? I plan on pushin about 1krwhp ... should they be coated or what?
Old Oct 26, 2016 | 10:44 AM
BlwnLs1GTO's Avatar
The -20cc Wiseco's are a great piston and very popular for Turbo builds. They include all rings. Upgraded wrist pins for sure IMO for that power.
But it also depends on what Fuel you're running, heads and CC's as well as Supercharged or Turbocharged.
More info and you'll probably get more responses from the guys here with loads of experience.
Old Oct 26, 2016 | 11:29 AM
xdanny510x's Avatar
Most likley 91 octane
Old Oct 26, 2016 | 01:18 PM
conan's Avatar
Turbo or supercharger ? Street car or track car ? What heads with what cc combustion chamber are you going to run ? Meth injection or just straight 91 octane ?
Old Oct 26, 2016 | 02:33 PM
pantera_efi's Avatar
Default PVD Piston Pins
A "black diamond" PVD coated piston pin would be a good upgrade.
The LS-x pins are "short" (2.25") due to crankshaft Target Wheel placement.
Thus piston engagement is low for that design.
You should use a 2618 Alloy for the piston.
The C:R: you have now is most likely 12:1.
The stated above boost level, fuel, head cc's questions should be answered.
Though to make 1K-RWHP you would need 22.lbs + boost
Lance
