430hp/400tq LS1 build verification
Car is an '92 Camaro that I'm starting to swap an LS1 into. Mainly will be a Sunday driver with A/C, maybe a few autocrosses or open lapping events, with one trip to the drag stip just to see what it'll do. NO drag radials, forced induction or spray. While not high on the list, I want it to be as quiet as possible and not lumpy at idle/cruise. What is high on the list is reliability. It's not a max effort no-budget build, but at the same time isn't a limited budget build either. I do want to be smart with my money tho, but not miss my goal because I didn't spend an extra $200 on 243 castings etc.
Starting with a high mileage 2000 LS1 Camaro engine with 241 heads. Once I get it running, I'll pull it later and get it rebuilt most likely by Texas Speed & Performance
main driving factor being I'm also in Texas. I will call them when I'm closer to pulling the trigger late 2017, but for now just looking to make sure I'm heading in the right direction. Goal is 430+hp/400+tq to the wheels.Bottom end
346/347cid LS1 block*, stock crank*
Mahle -4cc Pistons
Stock Rods
TSP Cam 25-TSP228232 228/232 .600"/.600" 114LSA
Johnson Lifters, LS2 tray
LS2 timing chain w/ timing chain damper
ATI Balancer - stock dia, ARP Crank pulley bolt
Camaro oil pan* w/ Improved Racing oil pan baffle
Top end
243 heads, ported by TSP, CC/CR to be determined, stock gaskets
2.02"/1.57" valves
TSP .660" dual valve spring kit w/ ti retainers
TSP pushrods
CHE trunnion upgrade
Air
K&N RC-5102 Filter* to 4" tubing*
85mm Truck MAF* w/ Halltech screen*
Ported stock LS1 TB*
LS6 intake* w/ heatshield*
LS6 PVC/valley cover*
Exhaust
Hedman Mid Length headers 45720 (1-3/4" to 2.5" collector)* coated by Poly Dyn*
Magnaflow Spun Cats x2 59906*
Vibrant Y Merge 2.5" to 3.5"*
Magnaflow Muffler 3.5" single exit 12909*
to be replaced later with...
Kooks Mid Length headers 22311400 (1 7/8" to 3" collector) coated by Poly Dyn
Magnaflow Spun Cats x2 59929
Vibrant Y Merge 3.0" to 3.5"
Fuel
LS1 gas tank* w/ racetronix pump*
FaSSter fuel rails*
32-36lb fuel injectors
Drivetrain
Diamond Stage 1 or 2 clutch w/ 15lb FW
T56*
LS1 driveshaft*
3.42 10-bolt w/torsen*
Electrical
LS1 PCM*, tuned 91 Octane min.
24x*
stock LS1 coils*
Some of these parts I've already purchased*, so would take some great convincing to go another direction for certain things. Asking now tho for the parts still to be saved up for and bought.
Last edited by Alien; Nov 21, 2018 at 12:23 PM. Reason: Updates (italics) per suggestions
Ported 243 heads are very good. But flow tends to be somewhat intake biased. Consider a 228/232-114 over a 228/228. If you were willing to live with a subtle chop, I'd honestly recommend more like a 228/236. Also, for some reason ported heads seem to like more intake lift and less exhaust lift. So, figure 228/236-114 0.620/0.603. Something like that.
I doubt at 430, the LS6 intake would be much of a restriction but a used fast 92/92 would guarantee you didn't leave easy power on the table.
Monster clutch is a great clutch, but if you can find a lighter clutch, it makes for very snappy throttle response (i.e. Fun). Just getting down to 30 pounds will really wake up the acceleration. If you have already bought the clutch, it's a good clutch. If you haven't, ask them about a lighter option.
On your exhaust, if you haven't purchased already, an x pipe is very worthwhile. Kooks would be crazy loud. The hooker black heart might be a very good option for you. X pipe will shift peak power up couple hundred rpm.
Nothing bad on your list, so if I made a suggestion but you already purchased, keep what you got.
I like you cam choice. It may not hit 430/400 on an honest dyno, but it should drive well and be easy to tune. The 228/228 has plenty of power in the usable rpm range for a street car, but single pattern cams usually don't impress on the dyno. If it feels strong and drives well, should matter way more than any dyno reading anyways.
Look into Morel lifters, skip the LS7 crap. The LS2 trays are nice for drop-in lifter replacements, or you can look into some link-bar lifters. You don't have to break the bank, but definitely do not skimp out on the valvetrain.
Don't forget the ARP crank pulley bolt. It is a way better investment than ARP rod bolts for stock rods.
Good choice on heads, valve size is spot on for the ~3.9" bore. I would keep the intake runner volume relatively small, in the ~220cc range, but that is just me. I would also shoot for whatever combustion chamber volume is necessary to achieve ~11:1 static compression. This is a little tricky because you should be measuring how far the your chosen pistons are above/below the finished deck @ TDC, and using whatever thickness of head gasket necessary to get optimal quench. Which is usually 0.035" to 0.040" on all aluminum LS motors. Once you know what thickness of head gasket you will be using, figuring out your static compression ratio won't be too difficult.
For the rockers, I would also use the Struab trunnion upgrade over the Comp version.
You seem to have a pretty good grasp on what you need. I am not trying to change your mind, but I think a true dual exhaust is always the proper way to go (if fitment is possible).
Good luck and keep us posted.
Take a look at the dyno sheet I've attached. It's from a friend's WS6 and the car is totally stock apart from a set of long tube headers, SLP lid,a Borla cat back exhaust and tune.
This is crank horsepower though not RWHP.
Noted.
I think exhaust is going to be my limiting factor. Car will be low (hence mid lengths over long tubes), and running true duals on a third gen is tight at best.
That's a problem I have researching... looking at the dates of the threads. LS7 lifters were the thing to have at some point. Morel's (on TSP) look good and only $100 more, tho the link bar ones are $170 more on top of that. Do the link bars provide that much more security against the lifter spinning?
Noted.
I think it's going to come to a fitment and clearance issue. I want the car to be as street friendly as possible, even with it's 3' nose overhang.
Updated the 1st post with recommendations. Thanks again!
One thing I've noticed missing from your list is what rear end you plan on running.
edit: I see now that you are running a 10 bolt. must have skimmed over that. Personally, I'd be more worried about it than I would be about your high mileage short block.
Also since you are using the LS6 intake, it can be fitted with a 90/92mm snout by Tuned Port Induction Specialists. The LS6 intake with the 90mm snout works very well and will gain hp over the stock LS6 intake. If high rpm is your goal the fast 92 will probably make more top end hp.
3inch cut out in the I pipe can also get some hp. Electric is the way to go. It's loud when open.
My RS has twin 3 inch cut outs off the header primaries...worth 20 hp but it's really loud.
A friend tore down a 300,000+ mile 4.8 and it cleaned up nicely with a hone & no over bore.
I also feel I'm fairly easy on equipment. I have ran a 3rd gen 10-bolt and then an LT1 10 bolt behind an LT1/T5 in my roadrace car. No issues so far with any rear end or the trans, then again maybe I'm just lucky.
I'm a bit over the loud exhaust stuff, or wanting a certain cam just for the sound. My 4.0L Ranger had a 2 chamber flowmaster on it for 13 years. My T/A had Borla. I'm old now (36) and want my wife to actually want to ride in the car as well as not annoy the neighbors at 6am if I want to take it to work.
Now that's really good to hear. Thanks for sharing.
Hi flowing cats definitely cut down on the exhaust smell, reduce noise and don't hurt hp much.
Regarding ground clearance my 91 RS looked like an airplane taking off after the ls1 swap due to weight reduction up front. The RS had the Eibach Sportlines and They had lower it about one inch, the weight reduction raised the nose about 3/4 to one inch. Depending on what you want and how much weight is lost that might be something to consider regarding the ground clearance. We cut half a coil upfront to level the car. Should have stay with that but cut another half coil to get the stance back and ended up a little to low. My RS lost AC, got light K, light hood etc.
I'm gonna keep an eye on this as our builds are very similar in though...except I want some nice, slightly aggressive lope & chop at idle (My ol man has a 71 Chevelle with a seriously stout BBC in it and I dont want to sound like a Honda when parked next to it.
)other then the cam, I plan on 4L65E...
Heads...I posted another thread here about it, but my LS1 came with 706 castings...so I was planning on TEA Stage 2's the 2.04" valves..
Seriously crazy how similar we are thinking...I got the LS6 intake in the shop on the shelf, HOPING to reuse the majority of the bottom end after a complete refresh...etc..
And great choice of Vehicle
Its third gen fever!
Cool, its not just me this time.
Mine flew off at the big end of the 1/4, about 30 seconds after the PA announcer said "those covers tend to come off on cars trapping over 110" He nailed it.
Clean car you have. Congrats on doing what you want with it.
You are right, I've had to turn around and pick up broken covers after they did the 3 digit fly off. I warrantied the last set and left em NIB..
Love your wheels...been debating on which way I want to go. I've always loved the 91-21 style, and I have a set off getting refinished now. But the ZO6 style is sweet too..
Looking back on my 6.0 build I should have spent the money I spent on my other mods on a stroker bottom end, I could always have done the heads, intake, cam, or exhaust later on with the engine in the car.
