Ceramic coating?
The piston "melted" UNDER the coating allowing "loose" pieces to destroy valves, rings, walls, turbines.
My method is to fit piston oil jet cooling AND Gallery Pistons.
I have had good luck when a PVD coating was placed on the valves.
I would ALSO coat the piston pins with PVD (black diamond) for this type of use.
There are many engines, European, the have coated combustion chamber/exhaust port PVD coating at EOM level.
Lance
When you say PVD coating, do you mean something like this?
http://www.techlinecoatings.com/hi-p...-coatings.html
(Mods, I don't think a sponsor sells these, but in case they do, just using it as a reference!)
Second, to Ceramic the piston ring-land/skirt would destroy the walls.
I too coat the piston crown with only VHT paint at times with unknown results and NEVER created a problem.
I WILL DUE THE RESEARCH for my Hydrogen fueled LS engine project.
I will try this coating you have recommended, thanks again.
Lance
MY 100% solution is PVD when required. (Physical Vapor Deposition)
We use coated Piston Pins, Ti-Valves, Ball Valves, Lifters, Rings, etc.
This type of PVD coating is referred to as "black diamond".
I have NEVER had a problem using this coating material.
Another type of PVD is Titanium Nitrate, great for steel top rings.
I have used this for Alcohol fueled engine use with 300% greater ring life.
Lance
