did a compression test....
Old Oct 29, 2016 | 08:08 PM
1bluels1's Avatar
Angry did a compression test....
got a 1998 z28 with 167k on the engine.
it would burn massive clouds while driving anywhere. wouldn't cloud up as bad if driven slowly to cruising speed.
starts up one crank everytime.
threw an oil catch can to see if that would help.
finally got around to doing a compression test....
#8 - 135psi #7 - 80psi (90psi with added oil)
#6 - 140psi #5 - 15psi with no change with added oil
#4 - 140psi #3 - 140psi
#2 - 140psi #1 - 140psi
I know kind of an obvious answer, only because I hate to hear it but am I going to need to rebuild the engine?
or can I get away with rebuilding the heads.
thoughts and suggestions encouraged.
Old Oct 29, 2016 | 08:25 PM
andrewss's Avatar
A leak down test would help determine where the problem/s are.
Any coolant in the oil or oil in coolant?
Old Oct 29, 2016 | 08:26 PM
1bluels1's Avatar
No coolant loss
Old Oct 29, 2016 | 08:43 PM
tug686spd's Avatar
I'd pull the valve cover and both rockers on suspect cylinder. Then hook up compressed air to that cylinder through spark plug hole. This will seat both valve and you'll be able to hear where your problem is by where you can hear the air escaping. You'll hear it in either the intake, exhaust manifold or crank case.
Old Oct 29, 2016 | 08:48 PM
1bluels1's Avatar
So a leakdown is what really determines if i need to rebuild eh? Got it!
Old Oct 29, 2016 | 11:48 PM
RockinWs6's Avatar
Number 5 and 7 are notorious for breaking ring lands cracking etc..........I'm sure you can guess the rest. Ask me how I know? Does it knock cold? Seriously with those numbers I would yank the heads, inspect the pistons. You'll see the damage easily with the heads off.
Old Oct 29, 2016 | 11:50 PM
1bluels1's Avatar
no knock at cold start.
....and how do you know then?
Old Oct 30, 2016 | 12:01 AM
RockinWs6's Avatar
Same thing with my 99, smoked....... parts of number 7 ring lands in the exhaust. Car started and ran ok..........number 5 likes to do the same type of thing. They both run hot.
Old Oct 30, 2016 | 12:04 AM
1bluels1's Avatar
Sounds like I'm on borrowed time..
welp. Hopefully it's not too bad. Otherwise I think I'll do a 5.3 swap then.
Old Oct 30, 2016 | 12:08 AM
RockinWs6's Avatar
You can change the pistons easily, just buy a couple used ones and stuff um back in the holes. As long as the cylinders aren't too effed up. Gotta have some experience to to call what will make it though....I bean down this road a few times.
Old Nov 3, 2016 | 04:18 PM
Old Geezer's Avatar
Gasket blown between cyls?
Old Nov 4, 2016 | 04:23 PM
Forcefed86's Avatar
Get a cheapo $10 borescope on ebay and look down in the suspect cylinders. Sounds like you pinched a ring or something. Harbor freight has a nicer one but it costs more as well.
http://www.ebay.com/itm/5M-4LED-Endo...-/172318166104
Old Nov 4, 2016 | 06:24 PM
bigsticksupra's Avatar
so one day it just decided to start puffing smoke or did you overheat it, overrev, etc.?
Old Nov 5, 2016 | 06:12 AM
RockinWs6's Avatar
Number 5 & 7 says it all......I seriously doubt a blown gasket etc. The rings and piston overheat, ring expands too much and has to go some place. At the same time the very top edge of the piston is overheated, ring land + ring breaks and this can happen FAST! Leak down test will show all and a bore scope would tell some BUTT.................sometimes its just OBVIOUS its time to tear down.
Old Nov 5, 2016 | 01:33 PM
JD_AMG's Avatar
^This.
Although you may not be able to tell just with the heads off. My #5 piston looked ok from the top until i took it out and the ring was two pieces and and a little piece of ringland fell off.
Hate to say it OP but you probably need a tear down.
Edit: also mine never smoked, knocked or anything. Just showed up as a missfire on #5. In the low rpms you could tell, it would kinda sputter and buck.
