Timing Chain/ Dampener Recommendations for Road Course Use?
-Trick Flow® Timing Chain Dampeners TFS-30675540
-Trick Flow® Timing Chain Adapter Brackets for GM LS TFS-30675600
or
http://www.briantooleyracing.com/ls6...-88958607.html
car will be used for road course racing so there will be high revs and banging gears.
I was wondering if LS2 chain and dampener combo mentioned above were appropriate for my application.
For rest of the engine,
2002 LS6 crate engine
239 cam, 601/ 604 lift
7956 Comp Push Rods 7.450 .080
Comp Rocker Bearing Trunion Kit 13702-kit
ATI Super Damper Harmonic Balancer - 917277
Improved Racing oil pan baffle
Melling 10295 High Pressure Oil Pump
Samburg custom sub-frame and transmission brace.
Samburg custom aluminum radiator / air intake
MSD 8.5mm Super Conductor Spark Plug Wires
Turn one power steering pump
7/8" long tube headers (JTR) to custom fab single exhaust.
My task is also a LONG race such as BAJA racing and Air Boats.
I have fitted the L-92 VVT Tensioner with good results when the spring is upgraded.
This is a product I provide/sell
Lance, BTW my last road race car was a Lola-332
