Head studs
Old Dec 11, 2016 | 08:43 PM
moekluse's Avatar
Default Head studs
Hi everyone, continuing with my turbo build, and needing some head studs. I'm running a fully forged 5.3, ls9 head gaskets, arp main studs etc.
what are advantages of aged arp studs vs regular arp studs?
I need the most clamping force possible w/o going with 1/2 inch studs. are the aged studs worth it? their pricey as hell.
any suggestions would be much appreciated, thanks
Old Dec 12, 2016 | 11:04 AM
moekluse's Avatar
Anyone?
Old Dec 12, 2016 | 11:28 AM
MuhThugga's Avatar
If you are worried about lifting the heads after going with head studs, you may need to consider heads with a thicker deck or a 6 bolt block with matching heads.
Old Dec 12, 2016 | 12:02 PM
JoeNova's Avatar
Restricted User
Originally Posted by moekluse
Anyone?
If you want the best, buy the ARP aged studs.
Old Dec 12, 2016 | 01:17 PM
Mercier's Avatar
I'm a little behind on the vernacular of the more expensive stuff I've never had my hands on. Is "aged" a proper colloquialism for the "Custom Age" fasteners?
Old Dec 12, 2016 | 01:26 PM
JoeNova's Avatar
Restricted User
I mean, when you're talking about something, its usually best to use the most accepted forum term lol.
Or autocorrect sucks and keeps correcting it to Costume Mage so you say screw it and throw on a "D" so it stops changing it.
Old Dec 12, 2016 | 01:42 PM
Mercier's Avatar
Got it. Just trying to keep up with the cool kids...I mean mages.
Old Dec 12, 2016 | 01:46 PM
pantera_efi's Avatar
Default China Head Std's = OK
Your answer = None.
Your BMEP pressure could be STATED ?
My method for sealing a 4K HP, high RPM engine, is too use my studs @ $ 100.00.
I then use a gasket, that allows fitment of Cooper Rings, a BFG Nitrogen Gas Filled S/S O-Ring.
This is the same method as is done in the Buick Indy engine.
The same method used to seal 10,000 PSI in a pipe.
When HP is lower, these items may not be required.
Lance
Old Dec 14, 2016 | 10:04 AM
NHRATA01's Avatar
Well for one basic point, it makes it a lot easier to pull the heads in the future, don't have to mess around with trying to get all the coolant out of the bolt holes and drying them out.
I also like the idea of not repeatedly torquing the threads in an aluminum block.
Old Dec 14, 2016 | 12:14 PM
Mercier's Avatar
^^^This is why I use studs on all my builds, albeit the cheaper options. I might consider better studs if I was build a monster turbo application.
