Will these cam specs work in a 5.3?
Old Dec 18, 2016 | 11:28 AM
partemisio's Avatar
Default Will these cam specs work in a 5.3?
I have a lq4 that through a rod. I would like to keep the same cam that I have but I'm need opinions of if I might have clearance issues. I am gonna run the 317 heads on it FYI.
Cam specs are:
Adv. Duration 260 and 289
Duration @ .05" 211 and 239
Lift .600 and .623
LSA. 113
Old Dec 18, 2016 | 11:48 AM
xdanny510x's Avatar
Might clear.. but its always good too double check..
Old Dec 18, 2016 | 11:29 PM
stockA4's Avatar
Why so much exhaust duration? I'd be surprised if that cam would fit in a 5.3 without flycuting. Hopefully someone else will chime in on this.
Old Dec 20, 2016 | 05:48 PM
partemisio's Avatar
Admittedly, I don't know a whole lot about choosing a cam for a given setup. So I told Texas Speed what I was planning (turbo build) and they sent me this cam. It made great power in the lq4. Made 396whp through a t56 with the cam, longtubes from cx racing, and a single outlet 3" exhaust. That was N/A with stock timing also.
Old Dec 23, 2016 | 08:45 AM
gagliano7's Avatar
Just remember the 317 heads on a 5.3 is going to lower the compression quite a bit.
Old Dec 23, 2016 | 09:02 AM
KCS's Avatar
KCS
Moderator
It should clear, depending on the centerline it's installed at.
