Correct pushrod head Hole size for 3/8 pushrod???
Old Dec 20, 2016 | 05:28 PM
always faster's Avatar
Default Correct pushrod head Hole size for 3/8 pushrod???
I was running some expensive Manton 3/8 double tapered pushrods( double tapered to clear pushrod hole on head).
Now since im taking my engine out , the heads will also be disasembled.So while im there, i will ask the machinist to enlarge the pushrod hole to clear a straight 3/8 pushrods .
I will push more boost, change my Cr with a Little thicker cometic gasket and will probable need different lenght pushrods and straight 3/8 are way less expensive.
So what size hole do i need to clear the 3/8.
Please no slightly bigger answer, machinist need number not guess.
Thanks
Old Dec 23, 2016 | 05:43 PM
Dragls's Avatar
On my 243 heads I drilled them out to 1/2".
