How much before boring it?
Sounds like its right in the middle on tolerance. My question is at what point should it be bored?
This engine was bought off of Craigslist and I don't know its history. So far no major problems.... other than I've totally stripped it down. Starting to wish I had left it alone and ran it like it was!
Thx
A good rule of thumb is about .001" piston to bore clearance for every inch of bore when using hypers
About .0015 for forged
Bores might be worn .002 from perfect (which they likely weren't perfect from gm anyway), but if the pistons are also worn .002, those clearances combine to .004
Mic the pistons and set up a piston/bore clearance, don't just worry about the Bores alone
