new to ls world cam selection help
Old Jan 5, 2017 | 08:59 AM
fbody91's Avatar
Default new to ls world cam selection help
im new to the ls world. that being said ive been doing lots of reading. I recently bought a 6.0 to do a swap in a 93 Camaro for drag use only. plan is for stock bottom end, 799 heads, and a carb set up.
ive found with my reading that people say keep the rpms under 6300 rpm so I planed on shifting around 6k. so now my confusion. every cam I find in that rpm range seams mild to me with a wide rpm range minimal lift/small duration (im used to picking out sbc cams)
im using a carb and no street time so idle quality and low rpm mean nothing to me. some advice would be great thanks.
Old Jan 5, 2017 | 09:14 AM
Jtm2085's Avatar
Most people saying to stay under 6300 aren't building drag only set ups. I would figure out exactly how you are going to build your car and then contact some of the sponsors and get a custom cam
Old Jan 5, 2017 | 09:41 AM
fbody91's Avatar
the plan is to run a stock short block with heads and cam for a couple years so I can race the car. spending the majority of the budget on the rest of the drive train and suspension.
Old Jan 5, 2017 | 09:53 AM
Jtm2085's Avatar
I hear ya. I spin my stock bottom end to 7k all the time and will probably spin it higher with my new intake set up.
Old Jan 5, 2017 | 10:42 AM
fbody91's Avatar
I also don't think it will take serious rpms to meet my power goals. only looking to make 450rwhp. my low compression 383sbc in my 91 almost does that and I shift it at 6k
Old Jan 5, 2017 | 05:54 PM
99 Black Bird T/A's Avatar
With the carb, single plane intake i would imagine and track only, seems like a perfect candidate for a Solid Roller or Low Lash Solid Roller.
Something like 246/252 duration at .050 with 106-108 LSA, after lashed maybe 242/248 duration. Solid Roller T-rex basically with LSA to work well with the single plane & carb. Duration & LSA might have to be tweaked to piston to valve clearance concerns.
I think that might be a fun starting point for discussion with vendor's & cam guru'swith the goal of a getting custom solid roller.
Old Jan 5, 2017 | 08:00 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Kip @ Cam Motion did an Awesome job with my
Custom LLSR, check out SpeedTigger's first
LLSR with a 6.0, 243 heads, Vic Jr, & Carb.
