Is it possible to take off the Harmonic Balancer pulley without a flexplate?
Old Jan 17, 2017 | 04:56 PM
300LsZ's Avatar
Default Is it possible to take off the Harmonic Balancer pulley without a flexplate?
i have a 2002 LM7 5.3 I'm tearing down and getting ready to send to the machine shop the only thing is I cant get the harmonic balancer pulley bolt off because I cant hold the crankshaft still. Is there any way to get the pulley off without having a flexplate? I'm trying to skip on buying something that will only be used once
Old Jan 17, 2017 | 05:29 PM
NC_John's Avatar
I used the Chrysler three jaw puller from loan-a-tool at Advance. You have to modify your old balancer bolt to get the balancer pulled all the way off through.
Old Jan 17, 2017 | 05:41 PM
kenp's Avatar
I have used tools such as a flexible plumber's clamp and I have run a few bolts into the back of the crankshaft and used a crowbar across them for leverage to hold the crank. Also, a bit of heat on the bolt will help release the loctite. It can be done, just get creative.
Old Jan 17, 2017 | 05:50 PM
BlackDuk98's Avatar
Like keno mentioned, a few bolts in the back of the crank with a bar in the middle so that it locks into the ground or something works nicely. Use an impact gun will also help.
Old Jan 17, 2017 | 05:52 PM
300LsZ's Avatar
that's the exact puller I rented just couldn't get the balancer bolt off because the crank kept turning.
I'm going to try to use both those methods. I tried prying a wood 2x4 inbetween the engine stand and the rear cover and tried to turn it off but I ended up breaking the bolt that was in the crank. ill give it a go when I'm off work thanks a lot guys
Old Jan 17, 2017 | 05:59 PM
300LsZ's Avatar
Going to give this a try thanks a lot
Old Jan 17, 2017 | 06:35 PM
NC_John's Avatar
But did you trim your balancer bolt? You have to remove the balancer bolt and cut off the flanged section to decrease the diameter so it will pull through the puller tool. I used a grinder to do mine. It was a pita but it worked.
I trimmed my bolt, put it back into the crank, then seated the center bolt of the puller on the head while I torqued on it. The crankshaft will not turn if everything is set right.
There is some guy on YouTube with a video showing the method.
Old Jan 18, 2017 | 09:42 AM
300LsZ's Avatar
you happen to have the link?
Old Jan 18, 2017 | 09:46 AM
300LsZ's Avatar
I just found it actually aha thanks a lot this looks easy
Old Jan 18, 2017 | 09:48 AM
NC_John's Avatar
yeah, it made mine a piece of cake once I saw this.
(for anybody else interested -
Old Jan 18, 2017 | 10:39 AM
BlackDuk98's Avatar
Depending on what 3 jaw puller you are using, some have the end of the driving screw as flat, others have it at a point. If yours has a point on the end, I reccomend that you put a shallow drilled center. This will make sure that the driving screw does not want to walk out of the center of the bolt and will give an even pulling force. If you can throw the bolt on a lathe you can do that in two seconds, if not, just take the bolt head corners and draw lines across the face to find the center.
Old Jan 18, 2017 | 07:26 PM
91 Z28's Avatar
Use an impact gun for the bolt and get a 4" 3 jaw puller
Old Jan 18, 2017 | 07:54 PM
Monzsta's Avatar
You can shove a bar in the spokes of the balancer to lock it. Then go to Auto Zone and rent the tool. It's free if you bring it back.
Old Jan 19, 2017 | 09:24 AM
gagliano7's Avatar
Impact gun and you don't even have to hold the crank. With the 3 jaw puller i use a socket instead of the bolt.
Old Jan 26, 2017 | 07:47 AM
NC_John's Avatar
well... did you get it off?
Old Jan 26, 2017 | 10:24 AM
Joie_C's Avatar
I used a pneumatic impact gun and just held it down on there for probably 15 to 20 seconds before it actually came loose. The crank never moved on me. Also, somebody makes an LSx specific puller that has a really long center bolt so that you don't have to cut your crank bolt. Hope you got it all apart successfully.
Old Feb 2, 2017 | 01:00 PM
300LsZ's Avatar
got it off guys thanks A lot I ended up borrowing a flexplate from a buddy
Old Feb 3, 2017 | 09:43 AM
Paul Bell's Avatar
That's MISTER MODERATOR
As you were tearing down this engine, all you needed to do was drop a hammer handle between the crank weight and the block. It won't turn with a block of wood in the way!
