Gain from 243 to TrickFlow 237cnc heads
Wanted to to know what i can expect to gain from switching heads, i bought these heads last year but they have been sitting:
https://frankensteined.net/products/...trick-flow-ls1
finally got around to boring a 6.0l block 30 over and got a forged set up it in, compression is going to be the same maybe a little more than stock.
Just wanted to know what I can expect to see from switching heads + cam, et or hp gain.
Car has a DP nitrous set up with a 32 get to start with.
car went 9.89 at 133 on a 200* plate
NA on a 370 it'll pick up probably 20-30HP vs ported 243s depending on the cam. On the spray, you might touch 9.6x.
The thicker casting makes it better for even more spray. If you get to a 300 shot or more, it'd be worth the swap.
LSxSprayed,
Our exhaust port setup on that head is nasty. With you spraying 200+, expect to see some wicked gains.
-Russ
