Ported 243 question
thx
FU_I_AM_UltraZ,
Our website is being rebuilt at the moment from the name change. We use to be Frankenstein Racing Heads. $1250 + shipping would have your set CNC ported, CNC valve jobbed, Hand blended, Logo'd, surfaced and assembled. New springs with titanium retainers as well.
-Russ
Rise of the Phoenix is correct. We have a variety of aftermarket heads from Trickflow to Brodix to ALL-PRO and so on in stock as well.
But you mentioned you're looking to stay budget friendly. With that being said, a CNC set of 243/799s is definitely a killer setup on a budget.
-Russ
In the end, I would recommend aftermarket as-cast options from PRC or TFS if you don't already have 243 cores as their pricing is very competitive ~1500-1800 range. And they are going to make very good power. Of course, used aftermarket heads from TFS, AFR, MMS, or PRC will be closer to your budget and are fine at that price point.
The only other reason to run such a head would be if you're going to push 20+psi in a boosted setup and don't want the head to lift. And then spending every last dime on heads there makes even less sense. Get as-cast TFS heads for the thicker deck and turn the boost up.
I've been very happy with quality of both sets of TEA's. The old 2002 era Stage. 2 5.3 TEA's on my TA have been trouble free since 2002 for over 123,000 + miles. The TEA Stage 2.5 LS6's have proven to be capable of 500+ rwhp many times.
This is a fun read on LS cylinder heads...
http://www.hotrod.com/articles/hrdp-...ndroid-verizon
I decided against the larger valves with the Stage 2.5 porting, one reason is the stock valves (2.00" and 1.55") will flow more than enough with my current setup. Second and main reason is I am using the LS6 Hollowstem and Sodium filled valves.
^^What 01ssreda4 said. It's your money, your build and your passion. Whoever you decide to go with is solely up to you! We're here to help.
-Russ
