PTV clearance LQ9
Old Feb 1, 2017 | 01:08 PM
NOVALSX's Avatar
Default PTV clearance LQ9
Building an LQ9 with 243 heads and using a Tick SNS stage 3 cam with the milder lobes. Has anyone ran this combo and checked PTV clearance? I'm thinking about sending the heads out and having them CNC. Not sure how much they will flat mill them, just don't want to run into any trouble.
Old Feb 2, 2017 | 10:08 AM
NOVALSX's Avatar
Nobody has ran this combo?
Old Feb 2, 2017 | 10:16 AM
pantera_efi's Avatar
Default Eap = pv
Hi, I can help by using EAP.
I would need the cam specification, a Cam Doctor/Andrews lobe file.
Lance
Old Feb 2, 2017 | 10:18 AM
PowellSixO's Avatar
I'm sure someone has ran it before, but no two setups are going to be exactly alike. The best way, and only way to know is to check for ptv clearance yourself. Just like pushrod lengths, the only way to know for sure is to measure your own setup. It's a pain, but if it's worth doing, it's worth doing right.
Old Feb 2, 2017 | 11:42 AM
CAMMOTION PERF's Avatar
LS1Tech Sponsor
Do you have the LS1 SNS3 (234/242 | .61x"/.61x" | LSA111+2)?
or
Do you have the LS2 SNS3 (238/242 | .61x"/.59x" | LSA111+3)?
Either way, I would not recommend that you mill the heads at all with either of these cams. They are both pretty tight of piston-to-valve clearance.
Old Feb 2, 2017 | 11:53 AM
NOVALSX's Avatar
I understand it needs checked, was just hoping someone has measured it before with this combo. Just seeing how close it is. Just gone to clean up the heads a little maybe
010.
Tick has the cam as 238/242. Lift they have 61x and 59x so not actually sure the last number. LSA 111+3
Old Feb 2, 2017 | 11:54 AM
NOVALSX's Avatar
Yep, the LS2 version.
Old Feb 2, 2017 | 11:55 AM
LS1Tech Sponsor
010.
That camshaft is very tight on the intake side. I think you will find about .035"-.045" of intake valve to piston clearance on an LQ9 with stock heads.
Old Feb 2, 2017 | 12:19 PM
NOVALSX's Avatar
When you say stock heads are you talking about the 317 heads or 243? That sounds pretty tight. Should I not run them?
Old Feb 3, 2017 | 08:52 AM
LS1Tech Sponsor
Either of those heads will have the same piston-to-valve clearance if they are not modified from stock. While the 243s have smaller combustion chambers, the valve locations are the same.
Lots of guys are running those cams without issue. With that said, I would not reduced the piston-to-valve clearance any further.
