Building a 408 and need help with my main clearance!
Old Feb 1, 2017 | 09:24 PM
se7en_'s Avatar
Default Building a 408 and need help with my main clearance!
I had my eagle crank ground 010/010. The crank measures bang on the maximum spec. I'm using Clevite p series 010 bearings. The problem is my main clearance is 0.0015" I'd like to get some 001 extra clearance bearings but I can't seem to find any brands that sell a +0.001 clearance bearing for a ground 010 crank.
Does anyone know of any bearing companies that sell this bearing?
Old Feb 4, 2017 | 07:25 PM
se7en_'s Avatar
Anyone?
Old Feb 5, 2017 | 02:54 AM
RonSSNova's Avatar
You might have to have the crank made a smidge smaller.
.0015 is in spec though, right?
Ron
Old Feb 5, 2017 | 10:09 AM
RockinWs6's Avatar
That's within specs.
Old Feb 6, 2017 | 01:05 AM
se7en_'s Avatar
Safe for rpm race application?
Old Feb 6, 2017 | 05:37 AM
KCS's Avatar
KCS
Moderator
That's too tight IMO. You might want to check with the crank grinder to see if he can grind the journals on the low.
