Ls1 loose rocker arm bolts
Old Feb 4, 2017 | 08:46 PM
Stoval96's Avatar
Default Ls1 loose rocker arm bolts
Need advice, I recently installed a 224/228 cam in 99 Camaro SS and I upgraded to double valve spring, new pushrod and trunnion upgrade to 1.7 and I got it running back and went to get it tuned , and while taking a test pass , got it up to 6k rpm and got off and starting making a tapping noise in the heads so I took off valve covers and noticed that some of the rocker arm bolts where very loose,
Any solutions on why this happened?
Old Feb 4, 2017 | 09:19 PM
2xLS1's Avatar
Did you use a torque wrench when you tightened them originally?
Old Feb 4, 2017 | 09:59 PM
moekluse's Avatar
I run the motor for a few seconds, then re torque to spec. Make sure there's no force on lifter (when valve is open)
Old Feb 6, 2017 | 06:37 AM
vettenuts's Avatar
Did you follow the GM procedure?
Old Feb 8, 2017 | 11:25 PM
kinglt-1's Avatar
TQ the rocker arms to 22ft lbs with lifters on base circle of the cam.
