Looking for some advice
Old Feb 22, 2017 | 09:56 PM
TiGer85SS's Avatar
Default Looking for some advice
After a lot of time Im finally getting in position to be able to put together my little street car. The car is a 98 Camaro SS and the planned build is a 6.0/4l80e
My plans are to use the stock rods and install some wiseco pistons most likely because I have found a great deal on some. However the particular pistons that I am looking at come with a +4 dome and I am planning on running some ported 862 heads. With this combination I am coming up with a compression ratio of around 12.2 or so. This has me a little concerned because this will be a street car that will see a little track time. I think that I may be alright because I am planning on running a 236/242 6xx/6xx cam. So what I am really looking for here is for some of the gurus to give me some input on my planned build.
Old Feb 23, 2017 | 06:40 AM
KCS's Avatar
KCS
Moderator
I wouldn't run that much compression on pump gas. E85 would be okay though.
A competent machine shop should be able to mill off the domes for less than $100.
Old Feb 23, 2017 | 06:49 AM
PowellSixO's Avatar
Ditch the 862 heads, and pick up a set of 243s. If you're going to go to the effort, do it right.
http://www.lsx4u.com/lsxinfo/heads.html
Old Feb 23, 2017 | 09:09 AM
TiGer85SS's Avatar
Thanks for the info.
Old Feb 23, 2017 | 09:12 AM
TiGer85SS's Avatar
OK I will check with my machine shop. What would be the most compression that you would run on 93?
Old Feb 23, 2017 | 09:18 AM
TiGer85SS's Avatar
I also have the 317 heads that came with the 6.0 as well. Can I get those milled to about and achieve around a 11.5 compression ratio?
