Adjusting stock rockers with tr224/.561 cam
Old Jun 25, 2004 | 11:39 PM
LS1INSIDE's Avatar
Default Adjusting stock rockers with tr224/.561 cam
is this the same procedure as with the stock cam just tq down to 22 ft. lbs or is it different? do i have to cycle the rockers by locating tdc etc...??
Old Jun 25, 2004 | 11:44 PM
2xLS1's Avatar
22 ft lbs and you're good to go. If you're really ****, spin the crank a couple of revolutions and check them again. They won't change because you are tightening the rocker pedistal to the head.
Old Jun 25, 2004 | 11:48 PM
JoeyGC5's Avatar
Then about every 5k miles go over them again, if your **** like me
Old Jun 26, 2004 | 06:54 PM
LS1INSIDE's Avatar
cool thanks! i knew the ls1 was way easier than the lt1 I just put the heads on an lt1 and man the rockers are a pain in the a$$ to adjust
