Missfire
Old Mar 23, 2017 | 03:06 PM
Oldgtonick's Avatar
Default Missfire
Changed plug and wires cool packs are good but clyinders 1&4 are dead did a compression check and it had plenty lifters aren't soft and rockers are good what else could it be?? Also started backfiring through intake
thanks in advance
Old Mar 23, 2017 | 03:20 PM
moekluse's Avatar
Check for spark on those cylinders
Old Mar 23, 2017 | 05:23 PM
Oldgtonick's Avatar
It has it... it started popping in the intake now after swaping injectors
Old Mar 23, 2017 | 05:34 PM
RockinWs6's Avatar
Are the valves opening and closing? cracked springs?
Old Mar 24, 2017 | 11:05 AM
nine8ss's Avatar
Did this problem start after the wire/plug change or are you trying to fix a previous misfire?
Old Mar 24, 2017 | 11:28 AM
pantera_efi's Avatar
Default Wire Resistance
Hi, did you use Silicon Grease ?
Did you crack those plugs ?
Would you measure wire resistance AND report ?
What brand of SPW ?
What SP and Gap ?
Lance
