4.8 ls help
Old Mar 30, 2017 | 06:06 AM
Mr.z281's Avatar
Default 4.8 ls help
So I just picked up a 4.8 off a 2002 Silverado. I need help/ advice on what I should swap (heads, cam, springs, intake). Would it be possible to gain up to 500hp on just oem parts? N/a power for now.
Old Mar 30, 2017 | 07:16 AM
JoeNova's Avatar
Restricted User
4.8 are best for boost. If you want big N/A power, get something else.
Since the only OEM engine that made 500hp N/A was the LS7, I'm going to say that you can't use OEM parts to get to 500 hp on a 4.8.
Old Mar 30, 2017 | 11:07 PM
stockA4's Avatar
We need more information on your setup and goals. What is the 4.8 going in? Curb Weight, transmission type, rear-end gearing? These are the most important factors to consider when modifying your engine.
