How to pin cam bearings?
Honestly with all of that said and the possibility of complications or issues, its not necessary at all.
FWIW that block with the spun cam bearing i saw was built into an iron 383 and has been punished for nearly 70k miles now in a heavy truck.
Those locktite compounds would be alot better alternative. Using what you learned or heard on the gen1 stuff doesnt always translate to engines now days, even ls blocks. Esp with the advancements in material and machining.
https://www.jbtoolsales.com/loctite-...FZNgfgodokIAqg
I'll check out yellowbullet and post over there, since they may have more experience with this.
http://www.yellowbullet.com/forum/sh...d.php?t=485116
Stevieturbo is a member on here too so you can PM him for more info if you are that interested.
http://www.yellowbullet.com/forum/sh....php?t=1165594
http://www.erlperformance.com/wp-con...hure-Web-1.pdf
On this ERL Catalog scroll down to block Modifications and upgrades
I mentioned using the locktite before in other threads but some guys that never tried it posted up some garbage about the locktite causing the bearings to overheat<COMPLETE BS!
I don't like the grub screw idea at all. It may stop the bearing from spinning but if its loose in the journal its still going to move around and wear against the screw. Also what happens if the screws come loose? USE THE LOCKTITE.
with the set screws, you can do a couple things. if your going into the back of the bearing, only tap deep enough that the taps' lead allows the screw to run up tight as it protrudes into the cam bore to grab the cam bearing.
or you can peen the screw threads with a chisel to create a kind of mechanical lock tite if you will. it basically galls the threads as you tighten it and that locks it in.
pinning cam bearings has been really common for many years. it's actually kinda funny you guys are so incredulous about it. i guess thats kind of a blessing really, prior to ls engines it used to be pretty difficult to make 750hp. now days thats easy to do on a daily driver haha
locktite causing the bearings to overheat? thats def some BS.
how hot did you have to get it to release? the green 680 stuff i have on hand says it's good to 355* ---so with a typical engineered 150% safety margin it'd be plenty fine under any normal conditions unless the bearing is completely starved of oil
