02 ls1
Old Apr 25, 2017 | 09:46 PM
Daniel_ls1's Avatar
Default 02 ls1
would I have to fly cut the t-rex cam for my 02 Camaro ls1?
Old Apr 25, 2017 | 10:37 PM
Fly cut a cam???? Explain....
Old Apr 25, 2017 | 11:31 PM
thatoneguybriz's Avatar
I'll assume you mean fly-cut the pistons.
The only way to know for sure is to measure the piston to valve clearance. I have seen some threads where guys have had success jamming the cam in and others say the pistons had valve contact marks after running the T-Rex. Since there are several variables at play (have heads been milled, etc.) it's always best to check. If you do end up fly-cutting I think you can go .080" safely on stock pistons but maybe someone else can chime in and provide some more clarification.
Old Jun 19, 2017 | 08:57 AM
Ls1nyetrus's Avatar
What's the difference between llr and jyd cam
Old Jun 19, 2017 | 09:15 AM
AnotherWs6's Avatar
I think this guy ^^^^^ sold him his t-rex, lol.........
https://ls1tech.com/forums/generatio...treet-car.html
Old Jun 19, 2017 | 11:57 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Like we say the trex is very close so you should verify the specs.
Also make sure to use a high quality spring kit like the btr .660 kit. i would not chance it on used springs with unknown pressure.
That being said, most of the time it fits with all stock heads, gaskets.
