That doesn't look good-- oil filter analysis
Old Apr 30, 2017 | 10:25 AM
5_litre_eater's Avatar
Originally Posted by JakeFusion
Run some Joe Gibbs LS30 in there. My oil pressure is about 10psi higher with it.
I did hot idle around 40 and now it's closer to 50.
I'll have to try that during my next oil change. What oil were you running before?
Old May 1, 2017 | 07:51 PM
99 Black Bird T/A's Avatar
I was always under the impression it's not how much oil pressure you have at WOT but the change in pressure. I.e. the 10psi increase per 1000rpms.
I'd always heard that too but I think GM says 7 psi at idle and 7 psi per 1000 rpm for LSx engines is what's required.
Old May 1, 2017 | 09:05 PM
That is correct. Many engine builders told me 55 PSI @ WOT was perfectly OK. More PSI than is needed can cost HP. Although, I'd rather have more pressure.
Old May 1, 2017 | 09:13 PM
Here is an update:
I cut open the filtering material and found more things that scared me.
A few decent pieces of long, stringy metal pieces
A few pieces of what I assume is bearing material
Several small metallic pieces. Also several small pieces of red RTV
This is the dirtiest oil filter I've cut open -- and it only has 500mi on it. Notice more small metallic pieces in the bottom.
This is definitely not the worst filter I've seen posted on the internet, but it's by far the worst I've seen yet for the Camaro. What should my next steps be??
Old May 2, 2017 | 06:15 AM
vettenuts's Avatar
If it were me, I would start simple and pull the valve covers looking for metal. That might help determine if the valve train is the source. Go deeper as necessary. One thing that is bothersome is that the metal may be passing through the oil pump, which isn't doing the pump any good either.
One area of wear is the cam retaining plate, but it doesn't sound like you messed with it before this issue started.
Old May 2, 2017 | 10:50 AM
RedWS6 00's Avatar
Are they needle bearings on the end of the magnet? could be from the rockers, or the hydraulic lifters. Time to take the rocker covers off an inspect, but I think it's going to be heads off and inspect lifters too.
Sorry to hear this, hope you get to the bottom of it and get your ride sorted.
Old May 2, 2017 | 11:02 AM
That's a good idea. I will take the valve covers off when I get some free time.. I need to remove the yella terra's anyway, since it won't be driven in awhile. I guess after that I'll pull the front cover.
Old May 2, 2017 | 02:57 PM
No, they aren't needle bearings. And I agree, I'll probably have to take the whole damn thing apart.
I'm guessing my original idea of putting another 500 miles on the motor is a bad idea now?
Old May 16, 2017 | 10:52 PM
Tony @ Mamo Motorsports's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
When you have a bearing going out you know about it.....there are pieces (and lots of them) in the pleats of the filter. This is NOT a terminal patient here IMO.....but something is potentially up. Also real problems are occurring when your oil pressure is dropping....if you have been at 22 PSI for a year now and are still at 22 PSI I wouldn't be that concerned your engine is going away.
Also do NOT run straight 30W oil (or any type of extra thick oil) to combat an oil pressure situation you think is an issue....22 at hot idle and 55 at WOT is plenty with good synthetic 5W-30W oil. Thicker oil is a problem with the Johnson lifters....they are designed and clearanced for modern cars with modern lighter weight oils. You could compromise the function of the lifters that way.
Pull the valve covers and have a peak....check for seals hanging up and the inner spring chewing them up.....look around carefully and don't take anything for granted.
Install a new oil filter and lets keep a closer eye on things for awhile (assuming you don't find the culprit under the valve covers).
Don't even think about throwing in the towel yet.....its waaaaay premature for that type of action
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
Old May 16, 2017 | 11:03 PM
big hammer's Avatar
When you have something going bad it's pretty obvious... I'm with tony on this one. One time I seen a guy pull a planetary completely apart because he found a metal flake on the magnet. Wasn't a thing wrong with it.
If the oil pressure hasn't changed in a year I wouldn't be writing it off quite yet
Old May 17, 2017 | 06:56 AM
Good to know guys, thanks for the advice!
Currently I have 0w-40 in the oil pan, but I haven't stated the motor with it yet. Should I swap it out for 5w-30?
Old May 17, 2017 | 08:42 AM
  #32
Paul Bell's Avatar
That's MISTER MODERATOR
0-40 should be fine. What filter are you using?
Old May 17, 2017 | 11:10 AM
  #33
I'm using the K&N filter
Old May 17, 2017 | 01:41 PM
  #34
DailyGTO's Avatar
I went through something similar recently, though in my case the oil pressure did seem to get lower (about 5-10spi lower than before but still good), and I developed a very slight ticking noise. My filter and oil looked very similar though, with some gold. I sent a sample to Blackstone and they said it looked okay, pulled valve covers and everything checked out. The ticking noise got a bit more prominent (like a dirty lifter or something), so I pulled the whole thing apart. I found a slightly bent con rod but nothing else really amiss. I ended up grabbing another JY 5.3 and its working well so far.
So in conclusion: As long as you don't have any new ticking noises, listen to Tony, and if all else fails, buy a JY motor for cheap!
Old May 17, 2017 | 03:42 PM
  #35
98cherrySS's Avatar
Just a thought here but when I built my motor I sprayed copper on the MLS gaskets prior to install and had the same gold swirl in my oil for the first few changes. Don't know if that was the culprit but the oil eventually stopped showing the swirl. All is well 20,000 miles later.
Old May 17, 2017 | 04:33 PM
  #36
LS1Tech Sponsor
That's an excellent thought actually and could very well be some of the gold that Josh is seeing. The other small bits are somewhat normal wear as there aren't alot of them or enough to really warrant any disassembly or major worry. There is alot of moving metal parts in an engine and some slight metal fragments in a reasonably fresh engine is really normal. If it happened 10000 miles later after many perfectly clean oil changes I would be more worried.
-Tony
__________________
Old May 17, 2017 | 07:09 PM
  #37
-Tony
I really appreciate all the advice guys! I tend to be a bit parinod and over react at times. I'm going to remove the valve covers and thoroughly inspect tomorrow night, then put some miles on the car. I'm going to switch to the Joe Gibbs LS oil that was previously recommended and keep an eye on things.
Old May 17, 2017 | 09:43 PM
  #38
Paul Bell's Avatar
GOOD. Or Wix or Mobil1.
Old May 18, 2017 | 12:39 PM
  #39
I was previously using a Mobil 1 filter, but switched to K&N since it's suppose to filter down to 10 microns.
Old May 20, 2017 | 04:35 PM
  #40
Update:
I pulled the valve covers last night and everything looks great! It looks just as good as the day I installed everything. I let the car idle for 30 minutes and I heard no strange noises and the oil pressure looked good, so I took it for a 50 mile drive. No problems at all. Im going to try to put 200 miles on this oil and send it in for analysis. I have the Joe Gibbs LS oil on the way, so that's going in next. No wonder I just dropped 50qts of used oil off at autozone last week...!
I really appreciate all he advice you guys provided. It's nice to be a Mamo customer, knowing I can always ask Tony for help!
