New Cam ls1 Pushrod length
for reference the motor has a trick flow top end kit 515 hp and I am just swapping the cam to a lunati voodoo cam #60512. Which is 232 238 duration 599 and 601 lift and a 113 lsa. The car has 7.5 pushrods with trick flow 215 heads
Just installed a new cam shaft a few days ago, ordered pushrods to go with that cam, and they were 7.400". Feeling the pushrods when not under load I could just rotate them, which is correct.
You may find you need longer pushrods for your cam. I guess you will find this out with the pushrod length checker. Good luck with your install.
