LS6 crank position sensor leaking oil
Old May 8, 2017 | 02:17 PM
Biged412's Avatar
Default LS6 crank position sensor leaking oil
Tried twice to seal using high temp silicone and even a bigger o-ring. Any suggestions ? Thanks
Old May 8, 2017 | 05:19 PM
RockinWs6's Avatar
Is the crankcase vented properly?
Old May 8, 2017 | 10:08 PM
07NBSChevy's Avatar
Have you tried using a new correct o-ring for it? I would remove all the RTV as well with the new O-ring.
Old May 9, 2017 | 08:58 PM
S10xGN's Avatar
They rarely leak. Make sure it's not dripping down from the valve cover, cam sensor, or oil pressure sender.
