Clanking on startup?
Old May 10, 2017 | 03:57 AM
Ssslp99's Avatar
Default Clanking on startup?
have a small clanking sound on startup on my 99 camaro don't know if it's a big deal but doesn't sound good only last for a split second car does not sit Over a few days synth blend 5w30 is this common?
Old May 10, 2017 | 04:17 AM
Ssslp99's Avatar
Upon start, engine fires and as/when it settles down to idle you hear a tack, clank or sort of sound. You can only here is at idle and you can only hear it with the windows down. Then very tiny little ticking when cold if you let it sit there it gets quieter, and sometime after a minute it dies out all together. meanwhile As long as the engine is a bit warm this noise doesn't come back. but if you let it sit 8 hours or more it might come back
Old May 10, 2017 | 08:53 AM
Lifters.... how many miles on the engine?
Old May 10, 2017 | 01:43 PM
Ssslp99's Avatar
don't know it has a new ls1 in it has between 4K-50k just a guess
Old May 10, 2017 | 03:27 PM
1Clean98Z28's Avatar
maybe a leak some where on the exhaust maybe the header/manifold?
