need help finding heads
Old May 10, 2017 | 02:14 PM
Gabriel Ambriz's Avatar
Default need help finding heads
What's up guys, I have a quick question, I'm looking at purchasing a lunati cam, with an
advertised duration 270/282
duration @.050 219/231
gross valve lift .625/.651
lsa/Icl 112/108
I need some help finding a pair of AFR heads that will work great with this cam, I already have a BBK intake manifold 85mm with a BBK TB 85mm.
Thanks in advanced for your help!
Old May 13, 2017 | 01:47 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We would actually recommend the trick flow 220 fast as cast heads. Work great and have room to grow later. Better design out of the box cnc chamber, and good on the budget at 1750 for the set with dual springs to handle that cam no problem!
If you want more comparison data, email me rpmspeedtech@gmail.com
Thanks!
