Oil pressure fluctuating
(https://ls1tech.com/forums/generatio...-pressure.html)
Since then, I've daily driven the car (probably 2000 miles since) and everything has been solid until yesterday I noticed at a redlight that my oil pressure gauge was fluctuating a bit. It would be at 40-45psi like normal then randomly creep down to ~25 psi and after a couple sounds shoot back up to 40 psi. Drove the car today and noticed that even when driving at steady state RPM it would fluctuate as much as 20-30psi in the same manner. Revving the engine did increase oil pressure.
Oil pressure sending unit was last replaced about 6 years ago. I'm planning to start by replacing the sending unit again but given the timing since I last had pressure problems, seems too convenient for it to be a coincidence of a failing pressure sender right after a failed oil pump. What's the best/worst case scenarios? Worst = spun rod bearing maybe?
Could this possibly be a pinched o-ring on the oil pick up or would that have shown up much sooner after the reassembly?
