Gen III Rocker Arm Bolt Torque
Old May 23, 2017 | 10:59 AM
MikeSp's Avatar
Default Gen III Rocker Arm Bolt Torque
Most torque references for OEM 8mmx1.25 bolts are 22 ft-lbs, but Joseph Potak's Book ("How to Build and Modify LS-Series Engines", 2009) lists 26 ft-lb for OEM Rocker Arm Bolts, per the Torque and Bolt Specifications table in the back of the book.
Chris Werner's book specifies 22 ft-lbs. Earlier threads on LS1 Tech seem to agree with 22 ft-lbs.
To me, this 4 ft-lb difference actually matters. Two of my rocker arm threads started to strip right around 22 ft-lb, so I am installing Timeserts to repair the affected threads. I may actually install Timeserts for all 16 holes, since now I'm concerned about the aluminum threads.
Is everyone using 22 ft-lbs?
Old May 23, 2017 | 11:24 AM
KCS's Avatar
KCS
Moderator
I've always used 22ft-lbs without any problems.
Old May 23, 2017 | 05:47 PM
spy2520's Avatar
22ft-lbs. Also shouldn't be stripping at 25-26. Some aftermarket rocker manufacturers (Yella Terra) list 25 for theirs.
Old May 25, 2017 | 02:49 AM
07NBSChevy's Avatar
I use ARP studs which recommend 26 ft lbs. 22 ft lbs is for stock bolts. The bolt should not strip at anything between 22-30 ft lbs. Someone may have went a little crazy before on them.
Old May 25, 2017 | 07:51 AM
moekluse's Avatar
I installed new rockers yesterday along with new bolts. I torqued them to 22ftlb with no issue, I'm sure it had a lot more left in it
Old May 25, 2017 | 07:53 AM
98CayenneT/A's Avatar
22 ft/lbs and a dab of blue loc tite
Old May 25, 2017 | 12:27 PM
PowellSixO's Avatar
22 ft/lbs with a itty bitty drop of blue loc tite should be sufficient.
