LQ4 hard start after warm??
The current problem I'm having with my LQ4 is hard starting or not starting after the engine has reached operating temp.
If I open the hood and let it cool off for 5 minutes it will start back up.
Current set up:
LQ4 engine with cam and heads.
walbro 255
C5 fuel pressure regulator
8.1 marine injectors
Dyno'd and tuned currently.
I thought it was possibly a vapor lock issue. So I upgraded the cooling system, insulated my fuel line and fuel rails. No change, still having the hard or no start after warm.
Symptoms began soon after new 8.1 marine injectors. Could the injectors be leaking and flooding the engine?
Do you know if there is a way I can test the connectors?
This is my daily driver and causes a lot of embarrassing moments when it doesn't start back up. For ex: ordering food at the drive-thru. I had to push it out of line because I turned it off to order! Hahaha
Have you tried checking the spark once its warmed up to see if it does actually have spark?
