update to my broken spring
and I mean REAL lucky....
Broke #6 intake valve spring.....
Pictures
got a replacement spring.....
put it on... put the compression checker on.... spun the motor a few times with the starter..no coils or injectors on.... and I got good compression..and seals nicely with no leaks...
which means everything survived... no bent valves
In the very near future(next couple of weeks....) I will be buying some patriot gold dual springs.....
for peace of mind....
and because if one broke... maybe Its time for a replacement set anyways....
just gettting some heat cycles on the new spring... so I can drive it like normal again.....
I still can't figure out why more people arent running them who dont have the need for duals? The manleys also have less spring pressure than the comps. The Best V8 Stories One Small Block at Time
If you have single springs. You probably know when it goes BOOM and bends the valve pokes a few hole here or there.
Shoot you can just JB-Weld the spring back together and it will be good as new.
J/K lol!
I still can't figure out why more people arent running them who dont have the need for duals? The manleys also have less spring pressure than the comps.The Only prob. with 918's is they lose Spring Pressure way to soon with a decent cam
