Rocker arm scaring
Old Jul 5, 2017 | 01:53 PM
Jrivera's Avatar
Default Rocker arm scaring
I pulled my rocker arm noticed scaring where the push rod meets the rocker arm.
I am going to order another set but is there anything else i should check on? besides all the rockers arms?
Motor is out 1998 LS1
Old Jul 5, 2017 | 04:08 PM
nine8ss's Avatar
Got any pictures?
Old Jul 6, 2017 | 10:15 AM
LS1MCSS's Avatar
Check the pushrods also. If the rockers are rough, then the pushrods probably are too.
Old Jul 6, 2017 | 06:03 PM
cookseyb's Avatar
Sounds like a oiling issue if that part of the valve train is brinelling.
Old Jul 7, 2017 | 12:47 PM
joecar's Avatar
Are the lifters ok...? Are those cam lobes ok...?
Old Jul 8, 2017 | 02:20 AM
chrysler kid's Avatar
There should not be any scarring on the push rod side. You most likely have a bent push rod or a lifter problem
