Oil pump keeps failing
Old Jul 13, 2017 | 06:11 PM
Rroyall415's Avatar
Default Oil pump keeps failing
Installed a new timing gear and oil pump and both of them keep breaking what could be wrong
Attached Thumbnails Oil pump keeps failing-20170713_185833.jpg   Oil pump keeps failing-20170713_185831.jpg
Old Jul 13, 2017 | 07:04 PM
Are you centering the pump on the drive cog before tightening it up?
Old Jul 13, 2017 | 08:00 PM
Rroyall415's Avatar
With the feeler gauges right
Old Jul 13, 2017 | 08:10 PM
LLLosingit's Avatar
what chain and pump are you using?
Old Jul 13, 2017 | 08:41 PM
Rroyall415's Avatar
Cloyes gear and stock chain and melling oil pump
Old Jul 13, 2017 | 10:46 PM
LLLosingit's Avatar
Obviously something wrong, What engine is it?
Old Jul 13, 2017 | 11:04 PM
tug686spd's Avatar
Have you checked the crank snout for runout? Would take some serious pressure to break parts like that. Possibly an off center cam sprocket to. Did you roll motor over by hand after assembly to see if it spun freely? I'd first leave timing set off, pull all rockers so valves are shut, pull the spark plugs and have someone crank motor over while I watched the crank snout for runout/wobble. If you have a dial indicator great throw her on. If that looks good I'd assemble the timing set leaving front cover off, rotate motor over 2 full turns in 1/4 turn increments checking the slack in the timing chain each time. If chain ends up getting tighter in spots then your problems in the cam or cam sprocket. Was this a fresh rebuild?
Old Jul 14, 2017 | 06:25 AM
psychosid30's Avatar
How long did the pump and chain last after installation? Did it break right away or did it last a few 100 (or 1000) miles?
I keep looking at the photos and I've never seen one break like this...
Old Jul 14, 2017 | 07:07 AM
Old Geezer's Avatar
Gear cracked on install. Starting the engine finished the gear failure, taking out the pump??
Old Jul 14, 2017 | 08:56 AM
07NBSChevy's Avatar
Well you do not see that to often. Only thing I can think of is the Pump didn't have adequate clearance on the crank sprocket, or the gears inside the pump were jammed up if it failed on initial start up.
Was the crank timing sprocket pressed on all the way? If it wasn't, it could see it cracking the oil pump during torquing of the bolts.
Old Jul 14, 2017 | 09:46 AM
Rroyall415's Avatar
5.3 lm7 engine stock engine and it spins freely it happened 30 seconds after start up gear was pressed on correctly timing chain does have some slack
Old Jul 14, 2017 | 07:41 PM
Old Geezer's Avatar
Question ??
"keep breaking".... As in having this happen more than once?
Old Jul 14, 2017 | 08:25 PM
nawlins-tim's Avatar
Try buying a timing chain set. All one manufacturer. And make certain nothing is dragging on the inside of the cover.
Old Jul 15, 2017 | 06:08 PM
LS1MCSS's Avatar
If you look at the picture closely, it looks like there is wear in the area I circled. OP, does that area look worn to you? If so, it wasn't centered correctly.
Old Jul 15, 2017 | 06:47 PM
slogo's Avatar
Did you replace the pump because the original one broke like this? Or just because low
oil pressure? On the next one, a video of install would be entertaining.
Old Jul 15, 2017 | 06:50 PM
OP, you still haven't answered this question. It is important, as you might be repeating a mistake in your build.
Old Jul 15, 2017 | 08:02 PM
Rroyall415's Avatar
I replaced it because the o ring problem so went ahead and replaced it the first time it ran for 100 miles then the second pump only lasted 30 seconds
Old Jul 15, 2017 | 08:30 PM
There is something very basic going wrong here. Old Geezer might have hit upon it a few posts above. The timing sprocket/oil pump drive "cog" might have been broken during/right after installation, taking the pump out with it upon startup. You might want to consult a manual before attempting the next install.
Old Jul 15, 2017 | 10:35 PM
LilJayV10's Avatar
yeah if it lasted 30 seconds the new " never ever worked" pump was bad or it was installed wrong.
Old Jul 15, 2017 | 10:36 PM
LilJayV10's Avatar
holy **** i just looked at the picture. I would classify that under catastrophic failure.
