Piston Ring Compressor for a 6.0L ?s.
Metric
English
General
Engine Type
V8
Displacement
6.0L
364 CID
RPO
LQ4
VIN
U
Bore
101.618-101.636 mm
4.0007-4.0014 in
Cylinder Bore Diameter
101.618-101.636 mm
4.0007-4.0017 in
Cylinder Bore Taper - Thrust Side
0.018 mm
0.0007 in
Piston - Piston Diameter - Measured Over Skirt Coating
101.606-101.640 mm
4.0002-4.0016 in
Piston - Piston to Bore Clearance - Production ****************
0.022-0.03 mm - interference
0.0009-0.0012 in - interference
Piston - Piston to Bore Clearance - Service Limit with Skirt Coating Worn Off ************************************************** *******
0.07 mm
0.0028 in
This is the one I've used for 4" bore blocks.
https://m.summitracing.com/parts/sme-904000
I always make sure the machine shop tapers the top of each cylinder to help with this too.
Just buy it...
