No oil reaching the top of the engine...
Old Jul 29, 2017 | 02:29 PM
lemans1's Avatar
Default No oil reaching the top of the engine...
Hi all, I am having an oil pressure issue that has me baffled...
Last year my 2004 6.0 lost a thrust bearing. Time being an issue, I bought another engine and went with it. A few months later I disassembled it, had it cleaned and put it together with a crank kit, new bearings, new cam/lifters/pushrods, high pressure pump, and Holley oil pan. Installed it and had no oil pressure...like 5-7 lbs. I checked the o ring, primed the engine, and tried again. Still nothing. Thought maybe the pan was an issue...put original back on...nothing. Replaced the "barbell"...nothing. Put on a factory oil pump...nothing. checked oil galley plugs and camshaft retainer seal, rear seal...all good...no improvement. I have had this *&$@%! engine out and in like 5 times...I don't know what I could be missing. Anyone have any ideas? I pulled the sending unit out and cranked it and oil did spit out, just no pressure behind it when running...Nothing comes out of the pushrods. Any ideas would be greatly appreciated...What am I missing?
I did check the rod/main clearances before installation and they were in spec. Checked and changed the o ring multiple times.
Old Jul 29, 2017 | 04:32 PM
cookseyb's Avatar
Cam bearings are shot...
Old Jul 30, 2017 | 06:25 AM
07NBSChevy's Avatar
Like mentioned above, cam bearings could be the culprit. Unlikely, but their could be something blocking the oil passage to the top of the engine.
Is there anyway you can hook up a mechanical gauge and thread it into the port next to the oil pump on the driver side of the block. That will determine if the pump is actually creating oil pressure. I would remove the valve covers, poor some oil on the rockers and down into the lifters before starting and I wouldn't run it for more than 30 seconds.
Old Jul 30, 2017 | 06:59 AM
nightrider123's Avatar
There is a oil plug behind the timing cover that usually removed when cleaning the block. Make sure that was put back in.
