Lifters choice
Old Aug 13, 2017 | 02:24 PM
Fishmasterdan's Avatar
Default Lifters choice
Decided to upgrade lifters. Not really sure what lifters is right for my application.
So the heads are tsp prc 237 62 cc heads. .660 dual springs with 415 lb open pressure.
Motor is a balaced 370 nitrous race setup. I want to spin it up as far as I reasonably can. Not afraid to take it 8k. My balancer even balanced the flex plate and said it's good to 8500.
Light weight forged rods and pistons.
Cam is a bullet .625 .625 244/254 on a 114. Not sure how far that cam will get me.
Any suggestions on lifters?
Any ideas how far the cam will go?.
Old Aug 13, 2017 | 05:34 PM
sjsingle1's Avatar
after reading about failures of LS7 lifters.....i went with morels....if i had the coin....would have went with johnsons
Old Aug 13, 2017 | 05:45 PM
cookseyb's Avatar
With that kind of lift and spring pressure you need to worry more about your rockers-pushrods!! Any of the lifters should work, heard good stuff about the Morels. Why do you think you need to spin it that high, I would think 7K would be plenty, need to get it on a Dyno to see where the sweet spot is, no use tearing up **** just cause you can...
Old Aug 13, 2017 | 09:32 PM
I'm all about tearing **** up ��
Old Aug 14, 2017 | 02:56 AM
cookseyb's Avatar
LOL!! Let er RIP....
